Phone not ringing
Timtamarama
My phone will not ring and I can not even check my voicemail as it will not connect!
10 REPLIES 10
Timtamarama
I have been sent to the technical team for hopefully a solution!
@Timtamarama
contact to support team by  CS_Agent  to check out your account.
Timtamarama
Tired all that nothing seems to help! I also only have one bar on my phone so that must have something to do with it! I have had no issue with my phone until now
@Timtamarama
Check the status of service outages
@Timtamarama wrote:
Yes I am connect to public mobile
HI@Timtamarama   if you are connecting to PM now, then it could be problem with 3G network
Try to change your network Type to 3G Only.  After the change, it is possible the phone does not connect at all.  If that is the case, it confirms that there is a 3G network in your area.  Change it back to 4G or LTE first.  Then, you can try to test voice calls again at another location
HI @Timtamarama  sound like a problem with your account or with the 3G network
First, login to My Account, is the account status Active?
Next, try to reseat your sim card , make sure you power off when you reseat the sim
And, if you have another phone, also try to put the PM sim card there to confirm if it connects.  It could be your phone problem
Timtamarama
Timer
@Timtamarama
turn off device take out SIM card and reinsert back turn on.
use browser from computer,clear cache and cookies and use one page inPrivate mode,
To Login Page
your account status is Active.
RossN
@Timtamarama dial *611 is your account active?
will13am
@Timtamarama , are you able to confirm connection to the Public Mobile network on your phone?
