Phone no.
anth5
I tried to retrieve my old number. I gave the wrong information. It failed. I lost my original public number. Now I have no number and no way to use public mobile. Is there a way out
geopublic
@anth5  Open a ticket and provide the correct port information and you should be able to get your old number back from your previous provider. If not, then ask the moderator to assign you one in the area of your choice.
To submit a ticket to Public Mobile click here. Login to your community account and select your issue and submit your ticket. The ticket will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
will13am
@anth5 , every non deactivated account has a phone number.  Login to your self serve account and check.
totalUser
Are you trying to port out?
Your account can be expired up to 90 days and it's still possible to get it back. After 90 your account is terminated and your number released, you could still get it back with the help of moderators if it wasn't reassigned.
Are you able to log in? Did you ever login or did you pay by calling 611
Triguy
When you log into your self serve account is it suspended or deactived ?
Has is been more then 90 days since you last paid your account ?
popping
Create a moderator support ticket using the ? button at the bottom right corner of this page.
Moderator wait time is up to 2 days.
