12-17-2017 02:40 PM - edited 01-04-2022 03:07 PM
Hi I have a Samsung s7 that is purchased unlock from the Samsung store and used it on public mobile. I just signed up to another provider and when the new sim card is in it says network locked enter pin.
11-18-2018 04:41 PM
@srlawren wrote:
@Anonymous wrote:
@bjpubxr wrote:If you didn't buy the phone through Public, its likely the manufacturer.
Just for clarity...Public Mobile doesn't sell phones.
@Anonymous just for clartiy... they used to. FYI. They haven't for several years now, but they were not originally a BYOB provider.
What?...no open bar? Crap. 🙂
But seriously...thanks. I did write in the present tense. I see now that the thing I replied to did technically write in the past tense.
11-18-2018 01:02 PM
11-17-2018 12:30 AM
11-17-2018 12:27 AM
I've never heard of this happening before, but I did have a problem unlocking a phone from an old provider many years ago. I bought an iPhone 6 from a provider about 4 years ago, but it was locked and part of a contract plan and I bought it at a reduced rate. A few months into the plan, I wanted to switch, so I paid to buy out the phone since I liked the phone. The provider told me it was unlocked, but it wasn't, so when I activated my new service surprise surprise. I had to call the old provider back and work the issue out. It ended up not being the iPhone, so just be sure to check all angles on this one. If you didn't buy the phone through Public, its likely the manufacturer.
11-08-2018 09:10 AM
@Csokool, you can send a private message as described in the thread above, the Moderator_Team will be able to assist you.
Really, you should be able to go to any Telus or Koodo store to request an unlock code as the carriers are required to unlock the phone.
11-08-2018 08:57 AM
For you LG 4 you will need to buy a unlock code from Cellunlocker
https://www.cellunlocker.net
choose your Model and Telus as Network Provider.
09-30-2018 04:22 PM
I am having the same issue with my LG 4. I am leaving public mobile for Freedom. What is the code to unlock my sim network?
12-17-2017 03:23 PM
Ok thank you
12-17-2017 03:05 PM - edited 12-17-2017 03:05 PM
I can verify everyones information to you first hand - I've experienced this with my s7. It's a Samsung software feature. If you head to Samsung.ca, start a live chat with one of their agents, explain your situation, they are very easy to deal with and you'll have your unlock code in 5 min or less - they are extremely prompt to correct this problem.
12-17-2017 02:58 PM
Oh didn't know that. Thanks a bunch
12-17-2017 02:55 PM
It is a common thing to happen it locks to the first sim inserted into it. Has been discussed is past threads. It is a phone thing not a pm thing. Some iphones do the same thing.
12-17-2017 02:55 PM - edited 12-17-2017 02:56 PM
@Jafakin wrote:The question is why was it network locked to begin with from public mobile? This phone has been bought straight out from samsung
Sometimes, the Samsung phones are not "truly" unlocked. They are unlocked brand new but will automatically lock to the first carrier's SIM inserted to the phone, which seems to be your case.
Contact Samsung to see if they can provide you with an unlock code, or you can try sending a message to the Moderators to see if they can help (include your account number and phone number as well as your issue):
12-17-2017 02:52 PM
12-17-2017 02:45 PM
I think samsun caan provide you with the pin or you can ask the mods to unlock it for you.
