Phone is hacked
Umar1972
Somebody hacked my number and phone. They made SIM unregistered. How this problem is solved? I need help now.
@telemonster wrote:
If your phone is hacked you are VIP (but VIPs do not use PM). Most likely it is a glitch or weed
very interesting
Did you have any suggestions for the OP?
telemonster
Marsh
If this happened during the initial activating process. You'll have to wait 50 minutes then try again.
Same thing happened to me.
Unregistered sim card does usually mean that the sim card is not active, but not always. It's happened to me before but it was a tenporary network-end glitch. Log into you self serve account to see if your service is still active and to make sure that the sim card numner on the account matches yours.
Umar1972
How can I solve the problem regarding SIM registration?
