Phone compatibility
dboychuk
I am looking to purchase another phone and came across the Blu v90 and I was wondering if it is compatible with PM? Thanks
 @Anonymous : That's fine. So look around where you can find it, as you did, and corroborate the results as a consensus.
@Anonymous
i can't found no results for blu v90  manufacture website..
@dboychuk
i just found two info Frequency
Yes is will working with Public Mobile.
BLU V90 Specification - IMEI.info
Blu V90 - Full Specifications, Price, Features - phonedady.com
Dunkman
@dboychuk
As mentioned above, this phone will work with Public mobile.
Here are the specs on the phone:
https://aboutdevice.com/gadget/blu-v90/
The BLU V90 comes with the network
2G GSM 850 / 900 / 1800 / 1900 – SIM 1 & SIM 2,
3G HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100,
4G LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 12(700), 17(700), 28(700)
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
Come on @Anonymous , he's asking about the V90.
 @dboychuk : From a fairly quick search it looks like it will work here.
@dboychuk
just make sure your device is  BLU G90
visit Here link to you review full information,
visit  Here link, to check it all Provider in Canada about compatibility with any device..
