Phone compatibility
Theshark333
Does lg q stylo + compatibile on public mobile?
for public mobile phone compatibility
you have to put it a device brand for any phone to you can see all information
you can visit here >>
WillMyPhoneWork.net - Check if your phone works on a network
following  >> To find out if your cellular phone is compatible with our network, click here
or you can visit here >>
Get Started (publicmobile.ca)
Good Luck
amx96
Most phones are compatible!
Yes, it compatible, but to ensure that and also to ensure maxium utilzation of the available network frequencies, I would recommened the model number LMQ710WA.  The is the version that this sold by LG Canada. Details from the manufactuer at the following website:  LG Q Stylo+ | LG Canada
