11-28-2019 06:09 PM - edited 01-05-2022 08:11 AM
I'm wondering if the LG c440 is compatible with public mobile? I can't find it in the list of devices but the phone isn't old so I'm wondering if there's another name or model it would fall under. Or if theres another way to find out if it would work?
11-28-2019 07:20 PM
LG c440 flip phone will work with PM. Two family members are using this LG c440 phone on PM.
11-28-2019 06:13 PM - edited 11-28-2019 06:14 PM
If it's 3g frequencies include umts 850 and 1900 you will be able to talk and text
I believe b2 b4 and b5 are needed for lte
More info here https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/frequency/m-p/334371/highlight/true#M...
11-28-2019 06:10 PM
@Davery wrote:I'm wondering if the LG c440 is compatible with public mobile? I can't find it in the list of devices but the phone isn't old so I'm wondering if there's another name or model it would fall under. Or if theres another way to find out if it would work?
Yes, if unlocked, it'll work. https://www.lg.com/ca_en/cell-phones/lg-C440-f4n
