08-01-2019 02:00 PM - edited 01-05-2022 06:13 AM
My phone does not come up on checking compatibility site. Does anyone know if a Motorola moto xt882 work on public mobile?
08-01-2019 03:23 PM - edited 08-01-2019 03:29 PM
Based on what I see in internet search, this phone will not work since it only has 2g gsm and CDMA.
I found 2 threads with this same questiom and ended up merging them.
08-01-2019 02:40 PM - edited 08-01-2019 02:42 PM
Hi @Silvaggios
Did you use it with Koodo?
If it worked with Koodo it should work with pm as well they are on the same network.
08-01-2019 02:40 PM
If you like Moto phones, you can get a Moto G6 for $200.00 on Amazon,
Great phone me and my spouse both have one.
08-01-2019 02:34 PM
Public Mobile uses the following frequency bands:
Please note that this information is indicative only. Your phone's compatibility with our 4G or 4G LTE networks is based on the radio frequencies of your phone. Public Mobile does not guarantee that your phone will work on our mobile network.
08-01-2019 02:30 PM - edited 08-01-2019 03:40 PM
@Silvaggios wrote:My phone does not come up on checking compatibility site. Does anyone know if a Motorola moto xt882 work on public mobile?
@Silvaggios No, it does not work. That is an 2g will only currently work on Rogers but not for very long.
Edit: See above.
08-01-2019 02:06 PM - edited 08-01-2019 02:26 PM
08-01-2019 01:57 PM
