Phone compability
Options
08-19-2019 06:46 PM - edited 01-05-2022 06:29 AM
Hello. I have a Nokia 5 and this model is not in the list "check compability". Please tell me if it will work with Public mobile.
Thank you.
Labels:
Phones
1 REPLY 1
Options
08-19-2019 06:56 PM - edited 08-19-2019 06:58 PM
As long as your phone gets 1 3G and 1 LTE band you should be okay.. however the more the better performance you get.
Public Mobile works on following frequencies:
- For 3G use (UMTS/HSPA): 850MHz/1900MHz bands
- For 4G/LTE use: 1700MHz/2100MHz bands
- For 4G/LTE use: 700 MHz band
Also from @sheytoon
Telus current LTE bands are (in order of band number):
- B2 (1900 MHz or PCS)
- B4 (2100 MHz or 1700 MHz or AWS / AWS-1)
- B5 (850 MHz or CELLULAR / CLR)
- B7 (2600 MHz or 2500 MHz or BRS)
- B12/B17 (700 MHz or MBS)
- B13 (700 MHz or MBS)
- B29 (700 MHz or MBS), for downlink only (SCC for CA only)
- B30 (2300 MHz or WCS), for TELUS only (not shared with Bell at this time)
- B66 (2100 MHz or 1700 MHz or AWS-3), not deployed yet
Telus current 3G bands are:
