01-10-2019 01:43 PM - edited 01-05-2022 03:01 AM
Having a problem with my phone staying charged for a period of time it dies after 2 hours
01-10-2019 02:05 PM
@Dkilcup098 wrote:It’s an older phone it’s a Sony Ericsson
If that's the case, I would worry about
I would really recommend you get a more recent smart phone. Even possibly you are just using a plan without data, it's much more convenient.
01-10-2019 02:01 PM
01-10-2019 01:49 PM
@Dkilcup098 Check the battery usage and see what apps draining your battery.
01-10-2019 01:47 PM - edited 01-10-2019 01:50 PM
@Dkilcup098 wrote:Tried replacing the battery and still no good
I would believe if you have a replacible battery, it might not be a recent year flagship phone then?
01-10-2019 01:44 PM
