07-20-2020 04:56 PM - edited 01-05-2022 12:11 PM
07-20-2020 05:07 PM - edited 07-20-2020 05:09 PM
@ca What happens when you dial 611 from your device? Note that you will also receive that message when you dialed a number incorrectly. Can you try calling another number?
07-20-2020 05:02 PM
@ca did you switch immediately, or set it to switch on the next renewal date? When you log into your self service account and go to the plan section. Which plan is showing? Thanks.
07-20-2020 04:59 PM - edited 07-20-2020 05:01 PM
Hi @ca ,
FYI, this is a public forum, so please edit your post (going to the 3 dots at the top righthand corner of your post and remove your name and phone number).
Did you JUST activate? Maybe your port is not complete yet.
Or Try:
-taking out your SIM and reinserting it
-rebooting your phone
07-20-2020 04:58 PM - edited 07-20-2020 05:08 PM
@ca when switching plans make sure you have "available funds" before deciding to change plans immediately.
try adding funds to your account and clicking the reactivate button.
or contact customer support
type "plan change fail"
(use the chat bubble options, then click "submit a ticket, click me" option)
https://publicmobile.ca.ada.support/chat/
make sure to check your inbox(top right corner envelope icon) periodically, for a message
