Phone Rings
Terry80
My phone only rings 3 times.
@Dooby wrote:
Turning off your voicemail might help? Like making it inactive if you don't need it?
Voicemail at Public Mobile cannot be disabled.
Dooby
slusagm
try changing it (but some said this no longer works)
**61*+17785804002 *11*30#
that would make it rings 6 times (30 seconds) before it goes to voicemail
17785804002 is the voicemail access number in BC, or you can use any voicemail numbers here:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Updated-list-of-Voicemail-Access-Numbers/...
