Phone Plan
Clive1
Hi, I have $50 in my account balance, can I use it to pay for my phone plan?
7 REPLIES 7
@sunflowershine wrote:
@Clive1 Definitely. Are you not on a regular 30 days plan?
30 or 90 day wouldn't be different other than when the person could use the balance.
sunflowershine
NW1
Yes, it can be used to pay for your phone plan as long as your payment is less or equal to 50 dollars. If your plan is more than 50 dollars you will need to top up your account.
hairbag1
If you have any Loyalty Rewards, Autopay Rewards, Community Rewards or Refer-a-Friend Rewards, they'll be applied, as well as Available Funds, before the credit card gets tapped. As you can see, there's potential for sustantial savings.
Good luck and welcome to PM.
geopublic
@Clive1 Yes, during your plan renewal the PM system will automatically use up the funds from your account balance first before using AutoPay if enabled.
Alex888
@Clive1 It will automatically use that when your plan renews, if you have autopay set up it will take the funds from your account first then charge the remainder to your credit card.
RossN
@Clive1 Yes you sure can!!
