01-26-2026 10:23 PM
Hi there,
I used to be with Lucky Mobile. I recently transferred to Public. I followed the directions for transferring my number and waiting more than 7 days. My number is still not transferred.
Please help.
01-26-2026 10:24 PM
hi @Jenn84
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway), you can submit ticket by direct message:
01-26-2026 10:24 PM
if you ported from mobile line, it won't be 7 days. Port could be stuck
there is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link
And CS_Agent will reply to your community inbox, check here:
