05-05-2020 04:28 PM - edited 01-05-2022 10:40 AM
I am having trouble finding my wife and my phone "sub model" on the compatibility list. Mine is an Samsung Galaxy A8 SM-A530W my wife is a iPhone SE MP852VC/A. Both were purchased through Rogers both do not appear on the compatibility list. Did Rogers just throw an extra number / letter in there to throw people off or is it truly not compatible?
06-28-2020 01:28 AM
Check here: https://willmyphonework.net/ - Make sure you select Public Mobile 🙂
05-06-2020 08:35 AM
Thank you everybody for your help!
Not AWOL just trying to limit my screen time as much as possible.
I am glad this community is so helpful, stay safe everyone.
05-05-2020 10:04 PM
Looks like @steelcity705 is one of those ones looking for help and then goes AWOL!!
05-05-2020 07:10 PM - edited 05-05-2020 10:15 PM
@popping wrote:Very old Rogers phones support only GSM(2G) only will not work with PM because Telus network does not support GSM(2G) signal.
Both Samaung A8 and iPhone SE first gen were release in 2016. Both should work with PM.
These 2 phones should work with PM.
A530W is newer than that as Samsung branded this as the Galaxy A8 (2018), but yes, both of these are more than new enough to have 3g frequencies available. There was an older model before called Galaxy A8.
05-05-2020 06:34 PM
@steelcity705 wrote:I am having trouble finding my wife and my phone "sub model" on the compatibility list. Mine is an Samsung Galaxy A8 SM-A530W my wife is a iPhone SE MP852VC/A. Both were purchased through Rogers both do not appear on the compatibility list. Did Rogers just throw an extra number / letter in there to throw people off or is it truly not compatible?
On the iPhone SE.
In settings, about, MODEL you will find TWO model numbers.
You will see as in my pic NLXQ2LL/A
Then touch that number and the OTHER Model number will show A1723
Does that help??
05-05-2020 05:46 PM
@steelcity705 if yoh head over to the telus website or google telus compatible phones thats a quick waynto find out if they are. This is because Public operates on the Telus platform.
hope you have it all figured out.
05-05-2020 05:02 PM
05-05-2020 04:45 PM - edited 05-05-2020 04:48 PM
Before you leave Rogers contact them to unlock your phones. Not long ago I've seen complaints where Rogers employees refused to unlock phones for former customers asking them to login first.
Both phones should work fine on Telus network as they have required frequencies, they just have to be unlocked (if not already)
Also don't forget to enter both emails that you will use for your accounts to qualify for flash sale here
05-05-2020 04:45 PM
@steelcity705 Any phone sold in North America is compatible both of those phones will work with Public Mobile without any issues.
05-05-2020 04:45 PM
Both are fully compatible with Public Mobile. A phone doesn't need to be in the list to work. The list will always be incomplete, and likely includes some mistakes as well.
05-05-2020 04:41 PM - edited 05-05-2020 04:44 PM
@steelcity705 the Galaxy is 100% compatible https://apn-canada.gishan.net/en/apn/public-mobile/samsung-galaxy-a8-2018
the iPhone se seems to be 100% compatible, though I can't find your submodel. https://apn-canada.gishan.net/en/apn/public-mobile/apple-iphone-se
Welcome to PM. Stay safe.
Here's 4 articles on activation and porting and the Refer a friend reward if required:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Just make sure they are unlocked and do at least a network reset on both phones before inserting the PM SIM and restarting the phones.
05-05-2020 04:38 PM
My iPhone SE works just fine.
05-05-2020 04:32 PM
If they worked with Rogers then they should be compatible with PM. Make sure they are unlocked. You can also check willmyphonework.net.
