Payment
Nikok
I had auto payment set up on switched plans.  I double payed as I payed one month manually.  I don’t see any credit.  Will I get my one month back or credit.  I assume it doesn’t disappear.
I tried to open a ticket but it’s not working
1 REPLY 1
@Nikok  If your plan renewed and then you changed it later that same day you would be charged twice .. and no refund as it’s prepaid .. if your saying you are charged twice for same plan change check cred card vaguely does one charge say pending and the posted . If that the case the pending charge should fall off .. but to get support here’s the link
while your already here and logged in the community
  • you can send a private message   To CS_Agents by clicking here.
