01-24-2026 08:45 PM
01-24-2026 08:47 PM
but does the service work?
if it does, then ask PM to check. But look like PM might add the $20 credit back for you couple days later, but ask PM to confirm
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
