Paying with credit card
hfennig
i am trying to pay for add ones and it won’t go through , my credit card is good
Jukebox
@hfennigHi, I'm sorry to hear that you may be having issues with getting some add-ons
"You can purchase Add-Ons by dialing *611, or by signing in to your Self-Serve account. Before you purchase an Add-On, we recommend you review your options here, so you know what Add-On best suits your needs, and how much it will cost.
*611
To purchase an Add-On using this method, you will need to have a payment card registered to your account. Find out how to register your card in Self-Serve here. Dial *611 on your phone, and follow the prompts to first make a payment using a Public Mobile payment voucher, credit card, or Visa Debit card. After adding funds equal to or greater than the Add-On you wish to purchase, follow the prompts to buy an Add-On. You will need your 4-digit account PIN to purchase an Add-On. You selected your PIN when you activated your account.
Self-Serve
To purchase Add-Ons using your Self-Serve account, follow these steps:
  1. Click on ‘Purchase Add- Ons’ on the Overview tab and scroll down to the Add-On calculator.
  2. Click the plus sign (+) to add and the minus sign (-) to remove selected Add-ons.
  3. When you’ve added all your desired Add-Ons, click ‘Buy Add-Ons’ or ‘Make a Payment’ below the calculator:
    • You will see ‘Make a Payment’ instead of ‘Buy Add-Ons’ if there are not enough funds in your account to make the purchase.
    • If you don’t have sufficient funds to purchase the Add-Ons, you will be asked to make a one-time payment equal to the price of the Add-On, less your current available funds. Click ‘Submit’, then ‘Go back’: now the button below the calculator will say ‘Buy Add-Ons’.
  4. Select ‘Confirm my purchase’, and you’re off to the races!"
JoyLuck
Buying add ons is a 2 step process. Check to see if the funds are in your account, Available Funds. You then need to go back in and purchase the add on.
Jb456
Do you have an apartment number? Leave that section blank if you do as well as suite.
