PUK key
bhough
I had to purchase a new esim because my neighbor is stealing all my families information. I tried to use a new pin code to lock the sim for safety and now it's asking for a 8 digit PUK key, which I do not know how to find.
1 REPLY 1
slusagm
Ask PM to provide sim unlock PUK
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
