PUK code
06-01-2023 06:31 PM
Our iPhone is on SOS mode, we talked to Apple inc it’s not an issue from their end
CAN NOT use it because of the PUK code, which can only be provided from the carrier and network provider
I have changed the PIN online but the phone is not taking it!
So we are paying for service, but not able to use it, every time I try to submit a ticket it gives me a 404 error code
do I have to contact CRTC for a refund
Service
06-01-2023 07:03 PM - edited 06-01-2023 07:06 PM
@publicmobile202 wrote:Our iPhone is on SOS mode, we talked to Apple inc it’s not an issue from their end
@publicmobile202 , submitting a support ticket through the chatbot isn’t working at the moment but they are working on fixing it! Please send CS_Agent a private message using the link below & explain what happened in full detail so they can help you fix it!
You can send a private message to a CS_Agent: -> Here
Customer Support Agents are available from:
- Monday to Sunday: 9 AM to 10 PM EST
A CS_Agent will respond back in your Community mailbox at the top right of this page (envelope icon to the left of your community avatar).
06-01-2023 06:36 PM
Thank you
will public mobile waive the fee for the new SIM
Apple said the network provider should be able to provide you with a new code.
06-01-2023 06:33 PM
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
If the phone was never used on PM network, it is very likley an error a carrier unlock which you need to obtain from your old carrier
call Samsung 1-800-726-7864 for a master unlock code.
The only info you will need to provide is the IMEI and where the phone was purchased|
open a ticket with PM Support using this direct link: https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened. CS Agent will reply to you there.
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier unlock code.
(PM would not be able to help with this)
