PUK code
Justice99
I need this code to get into my phone number reset pin
Justice99
@benfatto if you enter incorrect puk code 4 more times sim will be locked
benfatto
@Justice99 What is the exact message displayed after you reboot your phone with the SIM installed?
To reset the ability to use your sim card's security PIN (and to be able to once again use your sim card), you'll need to submit a ticket by going to https://publicmobile.ca.ada.support/chat .
