PUK code needed ASAP
pri14
My phone got locked while I was playing around with it. Now it is asking for the PUK code, the contact us button is unresponsive I cannot click on it to message public mobile. Please help.
22 REPLIES 22
Mary_M
Retraité / Retired
Retraité / Retired
Hey @lionmich24,
Thank you for the update, we're glad to hear that you're now up and running with us 🙂
Cheers,
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
lionmich24
Hello All,
Thanks for trying to Help.
I was able to call PM directly at this number(1855-478-2542)and they were able to provide me the PUK code.
I am up and running.
Thank you,
hopetindall
@imm1304 wrote:
Hey @lionmich24,
The default PUK was verified to be 1234 earlier in this thread.
If you have never changed it, then it must be 1234.
DO NOT use this as a PUK code.
PUK Code is 8 digits - it is not a standard value but different for each SIM.
The default PM PIN Code is 1234.
(If you enter the incorrect PUK code too many times - it will destroy your SIM)
imm1304
In that case, just wait for a reply to your message. It will most likely be delayed 😞
lionmich24
When i tried th PUK code
i m getting error
PUK must be 8 digits.
But thanks for the reply.
imm1304
Hey @lionmich24,
lionmich24
So when this issue occurred, is there a way to contact PM as it is vey urgent ?
I see some users waited 4+days  to get a PUK code.
lionmich24
Thanks!
IWIK
@lionmich24 highlight or click on Mary_M and hit send message
lionmich24
Hello all!
How i can send a private message.
I need a PUK code ASAP
hopetindall
@IWIK wrote:
I think actually I need it because I was messing around trying to get fixed dialing working and disables PIN2 haha
I believe PUK2 recovers from disabled PIN2
KirkK
Just a totally facetious comment here:
I guess the moral of the story is to not play around with your PUK. 😛
RMarshall
@IWIK You're not kidding when you say eventually! It's been almost 4 days. This is nuts!
IWIK
@RMarshall someone will get back to you eventually.
RMarshall
Hi - I sent an email a couple days ago with request #3611-8285 to have a PUK code sent to me and haven't received any response.
Can you you please send me one @Mary_M
Thanks!
IWIK
I did, thanks. We're in the process
imm1304
@IWIK, I hope you sent in your request via private message as well.  🙂
Mary_M
Retraité / Retired
Retraité / Retired
Good morning @pri14
It will be a pleasure for me to help get your SIM unlocked.
I have received your private message, and I will respond shortly.
Cheers!
Mary
IWIK
IWIK
Is this the same code we need to enable fixed dialing numbers?
pri14
Will do, thanks!
imm1304
Hey @pri14,
Send a private message to @Shazia_K or @Mary_M with your request.  Proide your PM phone number as well.
