PUK Code
Snowflake567
I lost my PUK code and sim is locked. HELP?
Snowflake567
Thanks so much, sent.
HALIMACS
@Snowflake567
Click the little white bubble on the lower right of screen and type "Need PUK"
Follow the PRECISE directions it supplies to the very end.
@Snowflake567   Open a ticket with PM Support, they can provide you the PUK code,
you can use this direct link:   https://urlshortner.tiia.ai/Oyn1L6 ,
select SIM Card PUK then Contact us and then Click here to submit a ticket↗
Or if you have trouble opening the ticket that way, you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened.  CS Agent will reply and work with you  via messaging there
