PROMO
Wishart1
PROMO NOT
DOES ANYONE ELSE GET THIS BONUS LOYALTY OFFER bs GO THROUGH THE HASSLE OF LOG IN THROUGH DESKTOP ONLY TO GET  PROMO CODE INVALID
1 REPLY 1
slusagm
Some had the same problem. Good thing in this case is you are not alone and PM will fix it and help
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
