10-26-2022 05:02 PM
10-26-2022 05:08 PM
@FT1 wrote:Hi, if I forgot my 4 digit PIN number for my account, how I reset this?
The PIN can be cahnged from inside your Self Serve account. After logging in, go to the Profile area and there will be a feature to change the PIN.
10-26-2022 05:08 PM - edited 10-26-2022 05:09 PM
Log in to your account and reset PIN.
10-26-2022 05:07 PM
You can login to the account and reset it there in the Profile tab.
