Overcharged
Pissedagain
Why was I charged $15 for a 1g add-on? It’s quoted as $10 on the app.
2 REPLIES 2
slusagm
I wonder if you bought the wrong addon.
Can you login to My Account and go to Payment History and check what you got? Maybe post is the screenshot
Or if you like to work with PM directly, open a ticket.  Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
Sansan
If that's a fact you'd need to create a ticket for agents to correct.
1GB in Canada data shows as $10 for 30 days.
