Outgoing calls not working, even for local numbers it complains that no long distance addon availabl
07-22-2020 01:43 PM - edited 01-05-2022 12:32 PM
Hi Team,
The Phone number is xxxxxxxxxxxxxx and since this morning getting message for any outgoing calls that no log distance calls are allowed.
Incoming calls are working fine though.
edited by computergeek541: phone number removed
Service
07-22-2020 02:11 PM
@prakash132 wrote:Tried it and still having the issue . Anyway to resolve it. Would someone be able to check on my account/phone number ?
Actual message is you are not covered by your plan. I am on a $15 plan
Hi @prakash132 ,
So, are you are on a $15 Plan, are you out of minutes...? Check your SELF SERVE account.
You can add 500 mins for $5 add-on.
If you still have minutes, then yes contact Moderator_Team, here
07-22-2020 01:55 PM
If you are not on a $10 or $15 plan with a limited number of voice minutes, you need to contact Public Mobile customer service. You can do that by going to https://publicmobile.ca.ada.support/chat and opening a ticket.
07-22-2020 01:51 PM - edited 07-22-2020 01:54 PM
07-22-2020 01:48 PM - edited 07-22-2020 01:49 PM
Usually, this is a matter or misdialing a number. Even if the number is being dialed correctly, this can sometimes be solved by simply dialing a 1 before the area code. That shouldn't actually make a difference, but the Public Mobile system can act strange some of the time.
