10-31-2020 07:22 PM - edited 01-05-2022 05:22 PM
I'm able to recieve texts and phone calls but when I send a SMS out it says "sent" but recepient doesnt receive them. ANy idea why this is?
11-01-2020 08:15 AM
On my Xperia, group texts (though only 10 addressees and a message that would be SMS to one person) are converted to MMS. I assumed that this was normal. Would "fair usage" pop up if it was an MMS sent using data instead? Just curious.
10-31-2020 08:53 PM
Yep 250 in one hour is definitely above and beyond normal usage... if you contact the moderators you have some sucking up to do... it may also just start automatically working after your "average" works it's way back down over time...
For bulk sending you might want to consider a VoIP service like voip.ms where you can setup a softphone or use their API to send texts as a pay per use basis. Even then I'm not sure if their terms restrict bulk sending, but I would imagine they'd have a higher threshold...
10-31-2020 07:57 PM
Thank you!
10-31-2020 07:52 PM
@Bobjones wrote:I think it could be. Im just not sure who to contact or what to do
Check with the PM Moderators.
To contact the Public Mobile Moderator_Team, there are two ways to reach them:
1 - Click the bubble comment circle on the bottom right hand side of your screen to talk to SIMon the chat bot or link:
OR
2 - Contact the Moderator_Team via private message using this link:
10-31-2020 07:48 PM
10-31-2020 07:47 PM
@Bobjones wrote:I never knew that feature existed. How does it work?
It only works if you know who the provider is for each recipient
You can send an email as text to your PM phone:
Send to [email protected]
(using your 10 digit phone number)
Better yet. Do you know their email address?
10-31-2020 07:45 PM
@Bobjones wrote:
I'm just wondering if it may have registered as spam and somehow blocked our outgoing texts.
Maybe...
Terms of service:
Use the service in any way that requires excessive network capacity or that may adversely affect other Public Mobile customers or the service;
Engage in any activity on the Public Mobile or partner networks that is seen as excessive or malicious, as solely determined by Public Mobile.
10-31-2020 07:45 PM
Many of them sesponded back. It's just recently that it stopped working.
10-31-2020 07:44 PM
@Bobjones test yourself.
Text a message like "hello" to your cell number. It should go right back to you. Does that work?
10-31-2020 07:43 PM
Yesterdays and todays.
It's jsut recently about 1 hour ago that it stopped working.
10-31-2020 07:42 PM
This sounds like - more than one receivers of this text did not receive it, is this correct?
10-31-2020 07:42 PM
@Bobjones Did the 200 go through yesterday with no issues? As far as you can tell, did NONE of the 250 today go through?
If you send a single SMS to one individual now, is it being received?
10-31-2020 07:42 PM
10-31-2020 07:40 PM
That's a whole lot of texts.
Have you ever considered using email for this purpose?
Can send to number@msg.telus.com
10-31-2020 07:37 PM
We have the 45 dollar plan unlimited plan.
I believe it may have been around the 140 mark but sent as sms.
We are getting ready for the holidays so we sent about 250 sms today for our promotion. The sms was the same to all our clients.
Yesterday we sent about 200.
10-31-2020 07:34 PM - edited 10-31-2020 07:37 PM
@Bobjones wrote:It happens when I send it any recipient.
We sent a promotion to our clients today via text and I'm wondering if we may have reached our limit in texts.
Then it would be extremely doubtful that you have the $10 plan. And why would you have chosen no texting with the old BYO. So it can't be any limitation of the service.
Is there a spam thing for a business? Did your text get blocked due to thinking it was a spam? Was it a group message? Maybe you hit whatever the limit is for here?
10-31-2020 07:33 PM
Hi @Bobjones
Which plan do you have? Is it an old one with limited texting?
All the plans currently offered include unlimited texting.
Are you using the native text application on your phone?
How many character are in your text? I believe if you are trying to send more than 140 characters, you will need to send it as MMS.
10-31-2020 07:31 PM
I tried but it did not resolve the issue.
10-31-2020 07:31 PM
A few more things to check:
1. Launch the Settings app, then scroll down and tap "Apps."
2. Tap the "Messages" app.
3. Tap "Storage."
4. Tap "CLEAR CACHE."
10-31-2020 07:26 PM
10-31-2020 07:25 PM - edited 10-31-2020 07:35 PM
Hello @Bobjones ,
Does this work?
ADDITIONAL info. EDIT - make sure the sender of the text has their Chat Features OFF as well.
10-31-2020 07:25 PM
Is it just this one person or for everyone you contact? Can you test others?
If it is just one person then maybe their phone settings have something set blocking incoming texts or your number.
10-31-2020 07:24 PM
@Bobjones Does this only happen when you send SMS to one recipient, or all recipients? Try sending to another person. Let us know.
