Others using my number?
Janis_ems
I see calls from my number on days i did not use my phone.  How do i contact support?
2 REPLIES 2
gblackma
@Janis_ems if the calls are to a xxx xxx 4001 number then it's to you voicemail. Stay safe.
Hi @Janis_ems ,
Your voice mail phone number will show up on your usage. Even when someone calls you and it goes to your voicemail. Is the number the same, that is showing up?
Are the last 4 digits 4001?
