OnePlus5
annaurbs
Hello,  I have a 2-part question: 1) is the OnePlus 5 is compatible on Public Mobile? It doesn't recognize the IMEI but I'm wondering if it can still work. 2) Is there a way to test it? I have a SIM card, just haven't activated it yet. Can I activate it to test it out, without paying the fees for a plan,  in case it doesn't end up working?
Here are the frequencies used by PM/Telus:  https://en.wikipedia.org/wiki/Telus_Mobility Check against your phone's specs.
Inserting an unactivated PM SIM shows No Service; if you see a message to enter a code it would mean the phone is locked to another carrier.
The sure test for any phone is to insert an activated PM SIM; $11 (plus $5 for the SIM) to do that: https://productioncommunity.publicmobile.ca/t5/Getting-Started/quot-Risk-Free-quot-Activation-costs-...
Suggested reading prior to activating: https://productioncommunity.publicmobile.ca/t5/Getting-Started/BE-PREPARED/m-p/112014#M20827
canucks4life
I have a OnePlus 5 and it is completely compatible with all PM/Telus network frequencies including 4G+/LTE advanced.
NDesai
If it is compatible on http://willmyphonework.net/, it should work fine with Public Mobile. The imei checker is broken and not accurate.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
xCameron94x
the IMEI checker is outdate/unreliable. Use willmyphonework.net, it has an extensive list of phones, and shows if the phone is compatiable. Just be sure you know your phones model # as many devices have different model numbers for various regions
