09-24-2015 09:23 AM - edited 01-04-2022 12:45 PM
Does anyone know whether the One Plus Two from Oppmart wil work with PM network?
10-25-2015 11:12 AM
10-25-2015 10:26 AM
09-24-2015 02:48 PM
I just checked out their site and by the looks of it . this seems to be the chinese variant..
the phone should still work but you wont have 4g lte. you can still operate at 3G hspa+
but if you dont "mind" getting slower internet speed, then you should go for this.
09-24-2015 02:40 PM
@Banujan To be more certain read through this post and its links: Where can I buy a phone to use with Public Mobile?
You might also find this cautionary tale about Chinese phones worth reading in its entirety: Re: Xiaomi Redmi Note 2, 'no service' after activa... - ( a week ago )
09-24-2015 02:40 PM
Hi there.. if you ordered the north american then yes .. it works fully with 4g lte.
if you order the chinese or european variant, phone will work at 3g not lte.
I'm currently using the one plus 2 north american .. and it works great.
09-24-2015 10:03 AM
If its the NA version, Yes
