On the fence!
04-26-2017 07:43 AM - edited 01-05-2022 02:00 AM
So I just want to see how many people switched to the new 55 for 4GB/month promo plan?
I am still unsure if it would be worth it....
Service
04-26-2017 03:25 PM
for me, it was the US roaming option that is so much cheaper compare to other companies
04-26-2017 12:41 PM
@DealHunter I would jump on it if you're in Ontario.... and remember that there are other opportunities to bring the monthly rate down even further.
Hope you see that you moved to PM soon!
04-26-2017 11:19 AM
@will13am indeed. The only cheaper options than the current $55 plan are Freedom's current 4GB/$40 promo (which, bleh. Not even worth considering really, unless you're one of the very few lucky ones that can take advantage of all its positives without being affected by its many, many negatives), or a Koodo QC 5GB plan.
04-26-2017 11:09 AM
This is purely a personal decision. If 4 gigs per month is required, there are not too many options out there at the moment that is in this price range. If less data is needed, then there are more options to choose from.
04-26-2017 09:52 AM
When I switchd it was a simple $$ comparison. how much will I save.
Some of the other aspects are:
- do you you travel out of provnce/canada often and do you need your phone to be active. No servic outside of canada, except USA with addon
- do you primarly call within your home provence or outside (deed to buy long distence addon)
- do you live in a border town or interprovincial town (ie ottawa and quebec, some issues there)
- do you have an unlocked phone (iphones cost about 50$ to ulock)
- will you buy your next phone outright or do you want a subsidised one
04-26-2017 09:34 AM
@DealHunter, as @WearySky has stated pretty easy criteria to see if this is the plan for you.
04-26-2017 09:07 AM
Simple decision making process:
Do the plan specifics work for you? If not, don't get it. If yes:
Are you currently paying more than the plan costs? If no, don't get it. If yes, get it.
04-26-2017 08:48 AM
In general its still a good plan especially if you are a medium - heavy data user.
I waas on a corporate plan that didn't come close to this price with less data.
Again though it depends on your data usage.
04-26-2017 08:03 AM
It could be a good deal if they have a similar plan with rogers or Telus, but are paying way more. Yes it is more expensive than the fall promo. But it could still be an appealing plan to some
