07-10-2018 10:22 AM - edited 01-05-2022 05:05 AM
I just changed my number through the public mobile website to a 437 number, and I was wondering if it was at all possible to some how get my old number back.
I read through the forums and know that if I want a new 416 or 647 number I could get a cheap sim card and port it here, but I didn't read anything about the possibility of getting my old number back somehow. Thank you!
Service
07-10-2018 11:05 AM
PLAN A: If you ported your number from Fido to Public Mobile, then changed your number. It may be possible for the moderators to retrieve it. Costs nothing to ask.
PLAN B: If you cancelled your Fido plan manually then it's gone. You will need to look around for the best deal from another Tier 1 or 2 carrier to get your desired area code. Once you've activated port-in the new number to your PM account. Lst year Virgin mobile data only plan, and Zoomer were reasonable - around $20 to activate an account. Don't forget some carriers now insist on activation fees.
07-10-2018 10:55 AM
Mine was from Fido, so I was thinking if it would be possible to contact them.
If not, is my only other option just to purchase a prepaid sim from any other carrier?
07-10-2018 10:49 AM
The chances of recovery are slim or none. None if it's an old area code, like 416/905/647 (seems PM does not have access to these), or if it is in use.
Slim if the moderators can find it.
07-10-2018 10:45 AM
It is possible, but I will be honest, not terribly likely. Depending on how long it's been since you've had it, another person may have taken ownership of the number. Retrieving a number is challenging, and is usually only done by a service provider if there is some extenuating circumstance, ie. if someone lost their number due to an agent error at a contact center.
07-10-2018 10:35 AM
Hello you have to try it to send a private message to Click here
In your message put it, please include.
- your account number
- your phone number
- your account PIN
- Detailed explanation of specific your issue
- them can help you a lot nice service Team
Good Luck
07-10-2018 10:33 AM
It depends on where your number came from bell Telus Rogers etc all had various numbers allocated to them. So if your number was originally from Rogers for example the number would go back to Rogers.
If it was a this family number you might have more success.
