Number porting
Anntipathy
I ported my number from Telus but I'm still not activated on the Public network. Infact, I have no service at all! I did the switch several hours ago.
7 REPLIES 7
Anntipathy
Thanks!  It is working now?
Anntipathy
It started working last evening. Thank you!
Anntipathy
Thanks everyone. It finally went through in the evening! I appreciate all your help!
popping
Is your phone notification bar showing "Public mobile" or emergency only?
If connected to PM, is you data working?  Can you call out or text out?
If emergency only, test your SIM card with another phone to eliminate hardware issue.
mimmo
@totalUser   there might be a stuck port, but you are jumping the gun with that sole conclusion.  With stuck ports outgoing calls and sms  work,  and so does data... no service implies other factors:  failed activation,  need a network search etc... more informtion is needed from the poster to identify the issue before contacting mods.
mimmo
no service that is strange.  stuck ports will still have service (outgoing and data)
does the sim connect to the PM Network?  have you tried doing a manual network search?
can you log into your selfserve account what does the status say?
did you get a welcome email from public (home actiation)
did your sim get activated properly?
your old telus sim should still work does it?
totalUser
Hi @Anntipathy
Please contact moderators it looks like your port is stuck
In the meantime please use your telus sim
Welcome to public mobile
