09-23-2019 12:50 PM - edited 01-05-2022 07:15 AM
I received a phone call stating that they are having issues porting my number. Need a moderator. Thank you.
09-23-2019 08:32 PM
@Natklad wrote:I received a phone call stating that they are having issues porting my number. Need a moderator. Thank you.
Usually, this means that number porting has failed because of incorect account information. Please double check the account number for the old carrier.
In the meanwhile, you should be able to keep using your old carrier's service.
09-23-2019 12:55 PM
You can contact Moderator by press that button in bottom right corner your screen with ? in it, and they will reply via private message you'll see a red number bubble in your top right corner screen in the envelope button - it could take 48 hour for reply.
