11-19-2016 05:54 PM - edited 01-05-2022 12:40 AM
Hey guys,
So I was thinking of adding my whole family into public mobile for the 40$ plan. I just went out to buy 5 sim cards but my family won't be back till tuesday. Is there a time limit on when I can transfer a number over?
Service
11-19-2016 06:50 PM
@Chelsea353 NO WAY your kidding right! only limit of 2 per Credit card?! that makes no sense! I'm doing like mine and 5 others! i would need 3 credit cards! lol.
11-19-2016 06:32 PM
Also make sure that you have more then one credit card, you can only have a limit of two accounts per one credit card!
CHEERS :):):) @rhyip
11-19-2016 06:12 PM
11-19-2016 05:59 PM
Above post is the best way. Create new numbers to secure the plan. Then port at any date afterwards.
Triple check every number you input to avoid errors.
11-19-2016 05:56 PM
What you can do is activate the sims and create them all with a new PM number that way it won't cancle their current sims. When they are back then start the porting process which will then cancel their old service provider as well.
