Not working
Colintd
Signed up and paid but by phone will not connect
2 REPLIES 2
slusagm
Esim or physical?
Make sure you remove the old provider sim or disable the old esim. Then Reboot and reset network settings
If you need PM helps further, open ticket
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
