a month ago
- last edited
a month ago
computergeek541
I’m trying to switch from Speakout to Public Mobile, I can phone out on Public Mobile but incoming coming calls still seem to be going Speakout because I’m getting a message that my voicemail is not set up and I did set it up on public mobile. I’m asl getting a message that the chat isn’t available at this time so I can’t enter a ticket.
a month ago
@BKNS27 wrote:It will go smoother if you use the Speakout account number rather than the IMEI. It will work but some members indicated they ran into porting issues.
Please do not spread misinformation. Speakout accounts do not have any account number that can be used for number porting. IMEI or PIN is the correct information to use.
a month ago
a month ago
I think I’ve discovered the problem. I contacted Speakout and they are using my IEMI2 number and I gave Public Mobile my IMEI1 number. Now if I can only get an PB agent to answer my call for help. Not an easy thing to do
a month ago
It sounds like porting wasn’t completed. Did you reply to the confirmation text from Speakout that you are porting over to PM?
You can dm a CS_Agent and they will get back to you tomorrow after 9:00am EST.
