12-11-2023 10:30 PM
Hi, I have been having problems with incoming calls/texts. Whenever anyone calls me, it goes straight to voicemail for that person. But If I can call the person and it works.
Service
12-11-2023 10:56 PM
@Truong8055 wrote:Hello,
Yes I am a new customer that has ported my number over and my data does work.
then your port is stuck. You will be able to send texts, call out, but unable to receive texts or calls.
I will private message your the Telus porting team number. Check your private message inbox.
12-11-2023 10:52 PM
Hello,
12-11-2023 10:49 PM
Are you a new customer? Just ported your number over? It might be an incomplete port.
What about data?
