Not receiving incoming calls
y-rowaida
I just join Public Mobile
I don’t receive any incoming calls ,they all go to voicemail ,I don’t why !! If anybody can help will appreciate
sakibomb
It might happen if you're located at a place that has weak signal when you received the call!
mimmo
@y-rowaida can you provide some additional details?
Does any other feature work? Outgoing calls?
What phone are you using?
New number or porting a number?
Is the voicemail from your old provider( indicates failed or in progress port) .you can use your old number in these situations
RobertQc
If you just ported, it takes some time, every hour or so remove your battery / restart your phone. It can take time on your first port over and there can be weird issues for a short period of time.
You should be able to stick in your old sim card if this was a new port to receive incoming calls.
If the issue continues you may have a partially completed port but most often ports just take a bit longer. One of the moderators can take a look, see if they need to do something to move it along.  Click this to send them a message
I know it can be a little frustrating to wait but send a message to the moderator team and include your name, account number and/or phone number and pin number and they will get back to you asoon as they can between Monday-Friday 9am-9pm (EDT) and Satuday-Sunday 9AM-7:30PM (EDT)
For more information about contacting a moderator Click Here
