Not liking
06-16-2018 06:40 PM - edited 01-04-2022 06:12 PM
I'm seriously thinking of moving on I need more data so I called 611 only option 200mb or 1 GB for 30.00 dollars that's a joke I still haven't seen the 6.5 GB offer that I was told being offered either and if there is how do you get it because it's not on the build your own plan deal 😐
Joining Public
06-18-2018 03:01 PM
@wardy4321 wrote:Just got 11 GB at Virgin 85.00 a month
@wardy4321 congrats that's pretty good!
If you're looking to save money there are ways to claw-back your data usage. I'm not sure where you spend most of it, but things like downloading music or Netflix shows while on Wi-Fi for playback while your're away from WiFi can make a big difference. When streaming YouTube when not on Wi-Fi, drop the resolution down to 480p to save a bunch--it doesn't look "that bad" for most videos while you're on the go to be honest.
06-17-2018 11:43 AM
06-17-2018 11:17 AM
@Wonder_why wrote:
@wardy4321 wrote:Does Kodoo offer packages 10 and above and how much
@wardy4321 about $90 but I pay $60 for 10 GB back in December month
https://www.koodomobile.com/rate-plans?INTCMP=KMNew_NavMenu_Shop_Plans
Koodo apparently brought that plan back with a tab for selected targeted (ymmv) users. Apparently if your with koodo add a phone to a plan and they give you the option to select the $60/10GB. If @wardy4321 is with Koodo he can try that. Or call his current provider to ask for a better retentions plan (if hes with someone else). Check kijiji few people sell ltheir 10GB plans, but as always be careful! Buyer beware!
06-17-2018 10:45 AM
06-16-2018 10:17 PM - edited 06-16-2018 10:19 PM
The other option would be to add the funds to your account and private message the mods to renew early say every 2 weeks but it's kind of a pain to always have to do that
06-16-2018 10:01 PM
06-16-2018 09:24 PM
@wardy4321 wrote:It's to bad they don't offer more packages with more Data
Not with PM, may be with Koodo, I know what you mean lots of 4K videos
I burn almost 10 GB Data a month with Koodo
06-16-2018 07:10 PM
06-16-2018 06:59 PM
06-16-2018 06:57 PM
Hey @wardy4321,
Please note it's only 3G data, not LTE, so you have to look midway it the data column to find 6.5 GB
06-16-2018 06:56 PM - edited 06-16-2018 07:00 PM
06-16-2018 06:55 PM - edited 06-16-2018 06:58 PM
06-16-2018 06:54 PM
I tried that and could only get 5GB max can you see what the max of GB'S they offer
06-16-2018 06:54 PM - edited 06-16-2018 06:59 PM
Well here i can see 6+0.5GB/30 days, or 18+1.5GB/90 days in my plan builder... Price is $50/30days or $150/90 days (3G speed data, not LTE).
But yes, if you need more than that you might need to change provider...
06-16-2018 06:52 PM
@wardy4321, I just went into my self serve account and I see the plan option you are referring to. Select build your own option at the bottom. Selection options will appear.
06-16-2018 06:52 PM
Have had to top up twice already and only been a member for 2 weeks I think I may need to find another provider I use my phone a lot
06-16-2018 06:50 PM
5GB and I can burn through that
06-16-2018 06:48 PM
What is your current plan?
