09-27-2022 01:16 PM
09-27-2022 04:30 PM
open ticket with PM support and ask them to check it out.
At https://publicmobile.ca/chatbot.
Start by typing "Submit a ticket", then click "Contact Us", Then click "Other", then click "Click here to submit a ticket
have trouble with Chatbot: Private message CS_Agent
09-27-2022 02:31 PM
Thank you very much, I’ve just got transferred my old # to PM
09-27-2022 01:41 PM
@Anic I will send you the number to reinitiate port request check your private message envelope
09-27-2022 01:39 PM
No, it isn’t fixed
09-27-2022 01:36 PM
@Anic ok so why the solution if it is not fixed?
09-27-2022 01:36 PM
It's easy to accidentally hit that Accept as solution button. You can undo it by clicking on the little down arrow in the upper right of that post and remove the solution. It doesn't make sense that a bunch of questions is the solution. Unless of course in there was a hint leading to the fix. A followup would be good to know then.
09-27-2022 01:34 PM
I’m not sure, I probably didn’t
09-27-2022 01:34 PM
I can call, but I don’t receive calls, I receive SMS
09-27-2022 01:29 PM
Do you have full service: you can call and receive calls, sen/receive SMS, Internet working?
Did you recently port your number? Did you port from real land line?
09-27-2022 01:27 PM
09-27-2022 01:24 PM
a few weeks ago
09-27-2022 01:23 PM
@Anic hi did you just activate an account and transfer a number?
09-27-2022 01:19 PM
How are you sending the 2FA code?
By email or text? Normally text is faster but lately both are just as fast.
Try both and see if that works.
