Not getting signal?
gwood
I started public mobile a couple months ago, in some areas I can't send or text even when I have bars, like I'll try to call then the bars disappear and a pop-up says there's no service.
The rest of my family is on Public Mobile too, and they aren't having any problems?
I have a google pixel 2?
please help
9 REPLIES 9
gwood
Thanks!
fdrcamb519
@gwood
Most likely a setting issue, hope you get back working soon.
Danchvn
@gwood I also have a Pixel 2 but haven't experienced that issue myself. If I happen to be in the basement I am occasionally told that there is a bad connection by people I'm talking to.
Triguy
Try a network reset. reset the network  Settings --> General --> Reset --> Reset Network Settings If you still need assistance then submit a ticket to a moderator by clicking on the question mark on the bottom right.
kselmak
Hi @gwood
Sounds like phone issue
Is it just texts or data and calls too?
Can you try different texting app if it's only texts
Can you borrow one of the phones that works well on public and use it for a day or two, just to see if it's your sim/service or your phone
gblackma
@gwood in the areas when you are having problems try switching your sim with another family member to determine if its a PM or phone problem. Try in order:
1.Restarting your phone. Turn it off, remove the SIM card, reinsert it, wait 5 minutes and restart it.
2.Putting your phone on aeroplane mode for 5 minutes. Take it off and restart.
Se if this helps. Stay safe.
RossN
@gwood hi try putting phone in airplane mode for five minutes then reboot phone
gpixel
@gwood
open settings
scroll down to system
tap on reset options
tap reset wifi,mobile & Bluetooth
tap reset settings and restart
shep22
@gwood hello try a network reset
