05-15-2019 03:58 PM - edited 01-05-2022 04:57 AM
Hi,
I've jsut transfered to public over from Fizz.
had so many recurring issues with fizz that wouldnt get fixed so i switched.
so i activated the new plan, i got confirmation the number transfered from fizz over to public.
calls are working just fine, i haven't tried texting yet (was a big issue with fizz).
i try connecting to data and nothing happens. i went and checked my APN settings and by default i have koodo and telus that were imported by the network.
for some reason i am not able to add public's own APN settings. could that be the issue?
phone is: ASUS ROG Phone ZS600KL
05-15-2019 04:33 PM
@Xsane wrote:Ye i popped in the fizz sim card and added the APN settings. they didn't show up on the saved apn list after i did though so i closed the phone in defeat and rebooted with PM sim card.
well low and behold. PM apn settings appeared to have carried on and were in the list and it let me select them.
i am now a man with access to data. thanks folks
@Xsane Thanks for the update, so I guess Fizz card also work and we can add them to the list. ![]()
05-15-2019 04:31 PM
05-15-2019 04:21 PM
The problem mentioned earlier about android 8.1 has to do with the add APN function being disabled. This external link discusses the workaround.
https://forums.redflagdeals.com/solved-fido-apn-miui-10-cant-add-apn-2239645/
05-15-2019 04:04 PM
@Xsane wrote:Hi,
@Xsane Yes that is definitely the issue. Are you running Android 8.1 by any chance? Many others have reported that running that version of Android on Asus does not allow you to add APN entries. The fix is to use a freedom or roam.com sim to add the APN or sideload an app to do it. SInce you have the Fizz card maybe try adding the PM APN usin your old sim card.
05-15-2019 04:01 PM - edited 05-15-2019 04:07 PM
@Xsane wrote:Hi,
Yes, that is the issue. Telus and Koodo APN settings will not work.
For reference, here are some guideline settings. https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-set-up-data-APN-on-my-smartp...
Is your phone running Android 8.1? If it is, you'll have to find a work around to get those settings added as some Asus models reportedly have that ability blocked out.
