Not conncting
bingzhenmz
Took out the sim card. And when I put it back in the slot, cannot find publicmobile network
Moid_I
Retraité / Retired
Retraité / Retired
@bingzhenmzSorry to hear you are not able to connect to the network, Are you still experincing same issue?
  • Have the SIM worked on this phone before?
  • If it was working befor and stopped recently please try to manually look for network under the settings
If problem presists Colic on Contact Us and Email Away
Cyber
@bingzhenmz,
Try to reboot your mobile.
You may have to find manually Public Mobile network.
Luddite
Try removing SIM card, hard reset on phone, then reinsert SIM again. Be sure SIM is aligned correctly.
