Not able to make local calls to certain numbers?
Jb456
Is Public Mobile having issues at the moment. I am in Montreal 514 area code. Also in montreal its 438 area code for another cell company. Some 438 numbers work and some are not working. When I try to call it says sorry it's not part of your plan you have to do an add-on. Even when that person calls me they get my voicemail.
How can I get this fixed?
17 REPLIES 17
Jb456
Resolved thank you
wrote:
wrote:
I tried 1 and +1 no luck.
Two people with same area code 438. One works fine and second does not work.
""Quote""Did you hear back from a moderator? Am curious as to the problem. :)""quote""
 _________________
Mod said it's been sent to a upper technician to investigate.
I will update thread when there is a resolution.
koimr1
Did you hear back from a moderator? Am curious as to the problem. 🙂
Somebody earlier in the thread mentioned trying to dail it as +1438xxxyyyy.  You mentioned you tried dialing with the 1.  Have you tried '+1'?  They are different.  '1' on it's own signifies long distance calling.  '+1' is the 'location' identifcation (I believe that's what it's called) for the mobile number.
Although it may be a local call, it is a different area code than yours, and for whatever reason, Public Mobile seems to be slow in updating the calling areas allowed within the provinces.  I live in a somewhat small City in Southern Ontario, and a call to someone with a 519 area code, in the same City acts the same way (or did) when I first joioned Public Mobile.  A ticket was created to add the area code and exchange to the allowed calling list (as far as I know it to be).
Two people same area code 438. One person all calls work fine second person can't call and when they call it goes to voicemail.
I will message the mods as suggested.
Thank you
mtfolks
If you were able to call them before but it doesn’t work now it is likely a switch (or similar) issue on either PM or Fido’s end of things that isn’t connecting the call properly. I highly doubt it’s account related.
A mod should be able to confirm on which side the problem lies.
koimr1
wrote:
All last week I was able to call the number. My friend is with fido if that helps
Oh ok - just to be clear, is it ONE number you are having problems with or several? Just that your first post mentioned multiple numbers but from this last post I'm reading it as one particular number.
In any event, do what the others suggested and ask the mods if there's any problems in your area or with your account first. 🙂
@Jb456, you will need to contact the mods and let them look into this.
To send a private message to a moderator click this link.
In your message please include:
  • PM Phone Number
  • 4 digit PIN (if you don't remember this then they will need at least 3 of the following to verify your identity)
    • account number
    • date of birth
    • complete address listed on account with postal code
    • email address on account
    • most commonly called numbers
    • alternate number listed on the account
    • last payment date and amount
    • last 4 digits of the credit card
  • Detailed explanation
Community Moderators are available from Mon-Thursday 9am(Eastern) to 9pm(Eastern) and Friday, Saturday, and Sunday from 9am(Eastern) to 7:30pm(Eastern)
mtfolks
@will13am Derp. Of course. PM doesn’t offer LOCAL calling packages.
Obviously too early in the morning for my brain to work properly. 😂
mimmo
I would ask the mods to look into it.
How can you get help with your account, activation, or service?
  • PM Phone Number, 4 digit PIN, Account email address, Detailed explanation of your issue
Don't know your pin?--provide any 3 of the following:
  • Complete mailing address, Email address, Alternate phone number, Date of birth, Last top up date & amount
How long until they reply?:
  • Office Hours: Mon-Thursday 9am to 9pm, and Friday, Saturday, and Sunday from 9am to 7:30pm [Totonto Time].
  • Messages are replied to during business hours and in the order they are received
  • Typical response time is between 1-3 hours, depending on message queue, but can be up to 48 hours.
  • There is no need to send multiple messages.
Additional Useful Information:
  • Search PM-GUIDE (remove "-" during the search) to find some informative posts and answers to many common questions about Public Mobile
wrote:
Could depend on whether or not the number is technically considered a LD call even if it’s the same area code. We have a similar split here in Vancouver if you’re calling Chilliwack which isn’t far and shares the same area codes. It’s still considered a LD call.
Is it possible that’s the issue here?
For province wide calling plans, all area codes within the province should be a "local" call.  I think Public Mobile has issues with resolving which calls are covered and which are not.  I recall in my early days with this service, I had issues making toll free calls.  Some went through and some were not allowed because I didn't have a long distance add on.
koimr1
Were you able to call these numbers previously? If so, when did this problem start happening?
mtfolks
I tried adding a 1 still does not work. Says sorry we can't complete your call. You don't have an active long distance plan and it's not covered please do an add-on.
Yet another friends number starting with same area code works perfectly.
will13am
@Jb456, do you put +1 in front of your number?  If not try that.
