08-23-2022 04:05 PM
@ Beautiful people:
I am glad to join your network. After suffering from poor network reception in the area where I live, I finally made the switch to PM having seen the high approval ratings of existing PM subscribers.
The issue though is that I am not able to receive calls on the PM SIM. I am fortunate to have the old SIM card and the PM SIM in 2 separate phones. I can do everything on the old SIM card. I can make calls, access data(internet) on the PM SIM card, but I cannot receive calls(All calls go to the old SIM card). Just to add that before I removed the old SIM card, I replied "YES" to the line port authorization text message. I am completely at a loss with respect to what I need to do to correct this issue.
Has any body experienced this, and how was it sorted out? Is there a number (or chat message) I can use to get a human help?
Thanks for your help
-PM Newbie
08-24-2022 11:36 AM
@esjliv: Thank you for additional contribution. Since I eventually got the problem solved by contacting CS_Agent (thanks @Timer for the fantastic lead), I thought I'd share my experience in the hope that someone else could find this useful too.
Apparently the IMEI number I supplied during registration was wrong. (I read that number off the Settings>General>About>Physical SIM section of my Iphone. I have no idea why that would be wrong). Anyways, they couldn't perform a successful number port with it. I was therefore asked to supply my account number with my previous cell service provider. With this information, a new port number request was sent to my previous provider, and it worked like a charm the second time.
Thanks to everyone who chipped in to helped. By the way, I think the idea of having a community for subscribers is a great one. Kudos to PM!
08-23-2022 07:54 PM
@waonn1 - since you did reply YES to the porting text, perhaps all you need is a restart of your phone with the public mobile sim card inside.
Also, perhaps perform a reset of the device's network settings to get your phone set up with the new provider's info.
08-23-2022 04:27 PM
Thank you @ Timer, for the suggestion. I have sent @ CS_Agent a private message. I am looking forward to hear back from them.
08-23-2022 04:12 PM
