10-27-2016 01:52 PM - edited 01-04-2022 03:45 PM
Any users living north of Kingston, Jones Falls / Elgin area? I'm in a marginal coverage area with Bell, but for the most part things work as well as can be expected... monthly service price just too much... I would like to move to this 4Gb/$40 month plan -- but before making the move, just want to see how the network access is for this area...
Best regards,
Service
10-27-2016 03:04 PM
thanks for all the replies... I've orderd a SIM and will activatge a 10-day plan and see what shakes out... fingers cross!
and I will check out the CostCo booster too...
Best regards,
10-27-2016 02:49 PM
Hi @bastage;
Yeah, don't trust those coverage maps, Eastern Ontario is fully of holes that don't really show there. I drive the Kingston - Ottawa trip a far bit, and it is normal to lose coverage for a bit on the 10 on either side of Westport (but not Westport itself). Closer to Kingston and Perth it is better. My brother-in-law (close to Franktown) had a similar situation to you and could only get reception in a certain spot in his kitchen, we ended up installing an in-home signal booster (Costco) so he could finally get rid of his Bell land-line, switched him over to PM 🙂
Anyway, as already mentioned, Bell and Telus share towers for most of this area, so reception will likely be the same. Best thing to do is get a 10 day plan to check it out, that will still give you time to get on this promo if you decide it is acceptable.
10-27-2016 02:11 PM
I was in Kingston, ON a few weeks ago and service was fine (if that helps)?
10-27-2016 02:06 PM
I checked the coverage map out already... pretty picture... I'm looking for some actual user experience in this coverage area... my current carrier (bell) also shows a pretty picture for their coverage map showing full LTE/4G coverage for my area... from my experience, I am in a marginal coverage area, so I connect/disconnect from the bell netowrk quite often... unless I place the phone in a particular area in my kitchen... 🙂
10-27-2016 02:01 PM
Hey @bastage,
According to this coverage mape (https://publicmobile.ca/en/on/coverage), the areas you mention are within PM's coverage. You can expect a good service.
I think Bell and Telus share network towers so you can expect at least similar coverage to what you have right now with Bell. Also, if there is a Telus store near you, check their coverage in your local area and thats the same reception you will get with PM.
10-27-2016 01:57 PM
Hi,
You'll have excellent coverage in your area.
You can verify that on this coverage map if you are curious for yourself.
Cheers,
Neil
