No service
Samanjot
My phone is on no service even I recharge yesterday
TheGx
@Samanjot :Did you get things fixed? You should follow up on this thread you created and let us know if you got service yet.
popping
Login to your account.  What is the amount in your available fund on the overview page after login.  If the available fund is equal or more than the fund you recharged yesterday, you have not reactivate your plan yet.
Please note that PM always ask for payment of full plan price without reward credit on reactivation.  If the amount in the available fund is equal to or higher than your plan price, click on the "Reactivate current plan" link to get your phone working again.
HALIMACS
@Samanjot , definitely check what @kb_mv states previously.
Other things to consider:
  1. Make sure airplane mode is off
  2. Power OFF your device, wait 1 minute, turn on and check for signal bars
  3. Check on account self-serve that your account status is Active
  4. While on self-serve, check that SIM card number under “Change Sim card” matches the SIM card number in your phone
  5. Make sure the device is not locked to a different carrier.
  6. Make sure you’re in a covered area and there are no cellular outages
  7. Change wifi calling preferences to Cellular Preferred or Cellular Only
  8. Set network mode to Auto
  9. Reset network settings
  10. Update device software to latest version
  11. Perform a manual network selection
kb_mv
@dabr wrote:
@kb_mv   Sad that we have to mention that as the first option to check now!
@dabr It is, but lately in light of what's been happening, the first thing that comes to mind and easiest to check is this.
dabr
@kb_mv wrote:
@Samanjot Go into your self serve and check under "Change sim card" that the last 4 digits of the sim registered to your account match the last 4 of the actual sim in your phone.
kb_mv
