12-09-2020 02:35 PM - edited 01-05-2022 04:25 PM
12-09-2020 02:56 PM
@Guy4 wrote:Yes doesn’t work
Contact a moderator and have them look at your account.
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
12-09-2020 02:49 PM
Yes tried that.
12-09-2020 02:47 PM
Yes doesn’t work
12-09-2020 02:47 PM
Yes of course, still no service
12-09-2020 02:47 PM
YEs I tried that.
12-09-2020 02:46 PM - edited 12-09-2020 03:11 PM
Split separate issue out to own thread in Getting Started section
12-09-2020 02:46 PM
Yes they match
12-09-2020 02:46 PM
12-09-2020 02:45 PM - edited 12-09-2020 02:46 PM
Check your last 4 digits of your sim card. See if they match your account.
In account click change sim card. Green arrow on pic below.
Do they match?
12-09-2020 02:45 PM
Did you try taking out the sim and reinstalling it? Restarting can help trigger reception but the sim might have moved .
12-09-2020 02:39 PM
I can’t receive calls I can’t make calls , my account is active
12-09-2020 02:36 PM
@Guy4 wrote:i have no service once again
Can you provide further details? I would suggest trying your SIM card in another phone if you have a spare to rule out any possibity of an issue with your device. When you say no service, you mean non call, no texts, and no data?
